rear wheel lug/bolt for ym 240
   / rear wheel lug/bolt for ym 240 #1
bassfishrman
Alabama
YM 240
I have lost all but 2 of the rear wheel bolts on my tractor. The only thing holding them in were lock washers, which apparently didnt work.
2 Questions:
Does anyone know what size the bolts are? The appear to be around 16mm.
Does anyone have a better method of keeping them in place other than a lock washer...maybe lock tight?
   / rear wheel lug/bolt for ym 240 #2
You are correct. 16mm x 30mm - coarse thread (maybe a 2 pitch? - my thread pitch gauge does not go that coarse). Lock washers should be more than enough to hold your wheel on. I suspect you may have had dirt or something between the wheel and the hub when it was put on - they were never completely tight- or that the holes in the wheel are damaged. Lock Tight works great but is overkill on wheel bolts.
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / rear wheel lug/bolt for ym 240 #3
I bought bolts long enough to go through the wheel & on the back side of the wheel I installed a nut on the bolt.
   / rear wheel lug/bolt for ym 240 #5
Per the YM240 service manual.
torque 123 ~ 152 ft.lbs
1267 (A50490)
1267 (A50490)
434669 (A48836)
434669 (A48836)
2006 Intellistrobe AFAD Trailer (A52377)
2006 Intellistrobe...
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2002 Genie Z34/22 34ft Electric Telescopic Boom Lift (A51691)
2002 Genie Z34/22...
