rear wheel lug/bolt for ym 240
   / rear wheel lug/bolt for ym 240 #1
bassfishrman
Alabama
YM 240
I have lost all but 2 of the rear wheel bolts on my tractor. The only thing holding them in were lock washers, which apparently didnt work.
2 Questions:
Does anyone know what size the bolts are? The appear to be around 16mm.
Does anyone have a better method of keeping them in place other than a lock washer...maybe lock tight?
   / rear wheel lug/bolt for ym 240 #2
You are correct. 16mm x 30mm - coarse thread (maybe a 2 pitch? - my thread pitch gauge does not go that coarse). Lock washers should be more than enough to hold your wheel on. I suspect you may have had dirt or something between the wheel and the hub when it was put on - they were never completely tight- or that the holes in the wheel are damaged. Lock Tight works great but is overkill on wheel bolts.
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / rear wheel lug/bolt for ym 240 #3
I bought bolts long enough to go through the wheel & on the back side of the wheel I installed a nut on the bolt.
   / rear wheel lug/bolt for ym 240 #5
Per the YM240 service manual.
torque 123 ~ 152 ft.lbs
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
