rear wheel gasket/seal replacment
   / rear wheel gasket/seal replacment #1
dgarrett
Kitsap WA
Kabota B2320 Narrow
I have a YM1820D with a leaking rear wheel flange that a am attempting to fix. The flange is now loose but I need to remove the axel in order to remove the flange and replace the gasket and seal. How does one remove the axel? Do I need to pull it off? Does it screw off or slide off?
Thanks,
Darrin
   / rear wheel gasket/seal replacment #2
the rear axle flange on 2000 unbolt but there is a post on here about a 2200 i think and it had to have the axle tube unbolted from the tractor and then messed with from the inside? not sure how yours is, but go to HOYE's site (look at there ad at the top of the page) and go to there parts section like your ordering and all the parts diagrams are availible to look at
   / rear wheel gasket/seal replacment #3
Don't take what I'm saying to the bank. Just based on what I see in drawings (not even of your model) I think your going to have to remove pto housing and maybe even remove axle housing. I can't see how the axle shaft can come out without removing the drive gear which looks to be held on the shaft with a retaining ring. Good luck!:thumbsup:
   / rear wheel gasket/seal replacment #5
Now that's what I call first class instructions.:thumbsup:
Yes Dougmac, how much do you charge an hour? I just live west of you in Kingston:)
My 1820D looks very much like the pictures on your web site, but I just ordered a manual from Hoyle today. I did have one question how did you press the out board bearing off? I have a press but I am not sure how I can get a hold of the bearing.
Thanks!
   / rear wheel gasket/seal replacment #7
Darrin,
Hi Neighbor! I used a bearing splitter to get the outside bearing off. If you have some thinner press plates that might work too. I don't have a press but I have a great buddy that lives in Edmonds that has one....
Doug
Well I got it done this week end, I did not have to take the axle assembly/housing off, but instead I just removed the PTO assembly to get at the snap ring at the end of the axle, then I firmly tapped the outer axle hub to remove the axle.
Removed every thing on the axle with my press.
When I assembled it I made a block that was tightly fitted between the other axle and the dissembled axle drive gear and bearing which was behind the drive gear. Then when I installed the axle with the new gasket and seal, I use the flange bolts and flange to pull it all back together. First I had to use a couple of clamps to get the flange and outer bearing pressed into the axle housing far enough to get the flange bolts started, but fortunately it all when back together.
Thanks for the help!
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
