Rear wheel bolts on 2815 fine or course thread??
   / Rear wheel bolts on 2815 fine or course thread?? #1
Wyld Bill
Central Maine
Mahindra
Trying to figure something out.
Can anyone tell me if the 14mm bolts on the rear wheels of a 2815 & 3215 are fine thread or course thread???:confused:
   / Rear wheel bolts on 2815 fine or course thread?? #2
Bill,
I can't help you with a 2815 or 3215 but can tell you the 2615 and 3015 use the same size bolts and I believe they are metric thread. 2815 and 3215 probably are metric too.
   / Rear wheel bolts on 2815 fine or course thread?? #3
metric bolt are sized like this 14 1.25 14.1.50 14.1.75 14.2.0 metric stud on cars most of the time 1.25 1.50.or 1.75 hope this helps
   / Rear wheel bolts on 2815 fine or course thread?? #4
Been in the mechanical-hydralic line of work all my life, but this metric thing has my mind boggled. I went to a fastener supply store and bought a metric thread gauge for a couple of bucks and it has made my life so much easier, might do the same for you too.:) there have been to many times when some one has rigged something differently and I get the wrong fasteners to match the ones in the job. Sometimes you can eliminate an extra trip to the parts store that way :) :) :)
Ok nobody answered the question yet. I already know they are 14mm. I need to know if they are course or fine thread.;)
   / Rear wheel bolts on 2815 fine or course thread?? #6
There are two fines 1.25 and 1.50. Buy the gauge?
   / Rear wheel bolts on 2815 fine or course thread?? #7
Actually there are 7 different metric thread pitches.
The bolt you are looking for is a 14 size x 25 mm length x 1.5 thread pitch that is a fine thread but there are still 3 more finer threads below that one.
STILL don't know if the thread on a 2815 rear axle & 2615 rear axle are the same:mad:
WILL A BOLT FROM A REAR RIM ON A 2615 FIT ON THE REAR RIM ON A 2815??
   / Rear wheel bolts on 2815 fine or course thread?? #9
Spin a bolt out AND CHECK IT! The wheel isn't going to fall off if you take a bolt out and lay a thread gauge against it.
   / Rear wheel bolts on 2815 fine or course thread?? #10
More like 17+ depending on the diameter. . The common and useful ones are 1.0, 1.25 1.50 and rarely 2.0. That is just in ISO. For those who have been working with metric fasteners since the 1960's I'm sure you remember JIS (single dot on the head) and the subtle pitch differences with those?
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
Portable Fuel Tank (A50515)
Portable Fuel Tank...
TYN T654 TRACTOR (A51243)
TYN T654 TRACTOR...
Informational Lot - Shipping (A52748)
Informational Lot...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
