Rear weight ballast, newbie
   / Rear weight ballast, newbie #1
ScottyChip
Newfoundland, Canada
Kubota B7510
Hi everyone
I have been a member for awhile, love the site and all the great information. My question, I have a large piece of heavy steel, which I would like to use as a rear ballast. Any thoughts; also do I need to add the top-link? I do have a ballast box, maybe I should just get the weight cut and put in the box. Size approx 38" long 8 " wide and 10" high. Not sure of the weight but made the back end light when put in the bucket with attached snowblower.
Thanks for the help.
   / Rear weight ballast, newbie #2
with the dimensions provided, it should weigh in the neighborhood of 860#. I think I'd use a top link to help stabilize it.
   / Rear weight ballast, newbie #3
anyone else think.... man i could make a sweet anvil out of that hunk! :D
you might have some fun fabing up a frame for that as i don think i can get my 3pt within 8" of the ground at its lowest point
but you could stand it on end, and weld a cross on the bottom for the lower 3point pins and a simple bracket at the top for the top link. the issue would be how do you store it when its not on. Without a wider base it would fall over and <gulp> watch those toes
Thanks for the replies, I have rethought the steel bar as a rear weight. A farmer friend dropped by the past weekend and agreed that this was probably more weight then my tractor should handle. I will use the ballast box and rocks or bags of sand approx. 300 - 400 lbs worth.
   / Rear weight ballast, newbie #5
That # of rear weight would likely be better off with a bigger tractor.. I'd go with the weight box.. etc.
soundguy
   / Rear weight ballast, newbie #6
To figure the weight. Length x width x height x .28 = weight (38 x 8 x 10 x .28 = 851.2 lbs.)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
JOHN DEERE 272-72" GROOMING MOWER (A51247)
JOHN DEERE 272-72"...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
