Tires !! REAR TIRE PRESSURE ? !!
/ !! REAR TIRE PRESSURE ? !! #21
Drive across some dry concrete with wet tires and you will see all the ground contact area and traction lost.
Although that might have some merit, I never put a lot of stock in it. Does a person do that every time and change the tire pressure with each implement change, counter weight on/off, etc?
/ !! REAR TIRE PRESSURE ? !! #22
10 to 14 psi is generally all that's needed in most compact tractor rear tires...running mine at 12 psig
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
1762 (A58375)
1762 (A58375)
Komatsu PC200 Excavator (A60352)
Komatsu PC200...
PUMP (A60736)
PUMP (A60736)
