Rear tire is flat! NH TD5050 rear tire torque value?
   / Rear tire is flat! NH TD5050 rear tire torque value? #1
Ranger1969
Tulsa, Ok
New Holland TD5050, Kubota ZD1211
Can't find the front and rear tire bolt torque rating anywhere in the operators manual. Front tire is 14.9x24, 24 mm bolt. Rear tire is 18.6x34, bolt is 27mm. Tractor is a NH TD5050 rated at 95 HP. Anyone have any info on this guy?
Thanks
Hey guys - I found this chart below. I am on the right track? A 24mm is M24 and 27mm bolt is M27. Now depending on the class of bolt 4.8, 8.8, 10.9 or 12.9 I can determine the torque value?
View attachment 09072017152047.pdf
   / Rear tire is flat! NH TD5050 rear tire torque value? #3
Thanks oldtink - yes it took a 24 & 27mm socket to remove the lug bolts and take the tire off. I got the tire patched, it cost $45 and took him about 30 mins. Wow that's a process to remove the tire from the rim - I don't think I ever want to do that, well worth the 45 to let him do it. I was informed for about $100 they will come to you, that would be nice not having to lug that huge tire around. I called several dealers. One gave me an answer - 600ftlb - but that sounded high. 1 said I had to come to them and read it out of the book - no answers over the phone and 2 more didn't call back. I believe the shop manual is $300 and I can't find it in the operators manual.
So Ebay is your friend when is comes to old operators manual/repair manuals. I found the operators manual for $40 & repair manual $99 on CD. That beats the dealers price and you would get it quick. I paid a dealer $28 and they printed and mailed it to me but its a huge note book printed and I think I would rather have the original bound version for $40. Also it didn't have torque values. I still don't have the answer to my torque question but I am getting close to an official answer. I found another metric torque chart in ft-lbs and it's similar to the first one. It's starting to look like the amount of force needed to torque is way more than my 1/2 torque wrench can produce 250 vs 600+. So I torque my rear tires to 220ft-lbs.
Question: utility tractor users - do you guy care about the torque value of your tires or do you just impact it on and called it good?
   / Rear tire is flat! NH TD5050 rear tire torque value? #6
I just use a snipe on a ratchet or power bar and tighten them evenly and pretty darn tight.
Unless you are highly skilled with an impact wrench you have no idea how tight they are when you are done. A big impact will tighten things unnecessarily tight.
   / Rear tire is flat! NH TD5050 rear tire torque value? #7
Torque can be misleading for tightening bolts. It depends on lubrication of bolt,cleanliness of threads, are threads all undamaged. Research turn of the nut for tension on the bolt
   / Rear tire is flat! NH TD5050 rear tire torque value? #8
I'm pretty sure Harbor Freight has them on sale right now.
   / Rear tire is flat! NH TD5050 rear tire torque value? #9
There are no harbor freights here.
And i am not sure what you meant by that comment.
   / Rear tire is flat! NH TD5050 rear tire torque value? #10
I guess, if he's not able to determine the size of the bolt and thread pitch there isn't much sense in worrying about a torque value and a ratchet and bar works......darn tight or **** tight if it's a shorter bar:drink:
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
John Deere 4000 Tractor (RUNS) (A50774)
John Deere 4000...
44507 (A51692)
44507 (A51692)
2012 Hyundai Sonata Sedan (A50324)
2012 Hyundai...
2007 Nissan Sentra 2.0 (A50120)
2007 Nissan Sentra...
