Rear tire flat on 2615
   / Rear tire flat on 2615 #1
Blue_Sky
Lower Alabama
2006 2615 4WD Mahindra
unfortunately the tractor is on the back part of our property. Looks like the lugs are 7/8. What type of tool can I use to get the lugs loose?
   / Rear tire flat on 2615 #2
I'd use a 1/2" breaker bar with 7/8 socket
   / Rear tire flat on 2615 #3
7/8" socket or 22MM metric will fit.
Threads are about an inch long. You will need at least a 6" extension and the breaker bar.
It would be helpful to spray some penetrating oil in the thread holes on the back side of the wheel.
Thanks guys. Your info. helped.
   / Rear tire flat on 2615 #5
I know that your tire fix is a done deal, but I keep a large air tank in my garage that when filled holds 120 lb of air. If I have a flat in the feild I just fill that thing and haul it out to my tractor and fill the tire enough to limp back to the garage were I can remove the tire with a impact wrench. It sure beats wallowing around on the ground. Jim
   / Rear tire flat on 2615 #6
i have the same thing - small air take - cost about 10 bucks - i also keep a can or two of the slime fix a flat stuff too
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
8ft Fork Extensions (A50322)
8ft Fork...
2019 FORD F-250 (A52472)
2019 FORD F-250...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
