Rear tire flat on 2615
   / Rear tire flat on 2615 #1
Blue_Sky
Bronze Member
Lower Alabama
2006 2615 4WD Mahindra
unfortunately the tractor is on the back part of our property. Looks like the lugs are 7/8. What type of tool can I use to get the lugs loose?
   / Rear tire flat on 2615 #2
I'd use a 1/2" breaker bar with 7/8 socket
   / Rear tire flat on 2615 #3
7/8" socket or 22MM metric will fit.
Threads are about an inch long. You will need at least a 6" extension and the breaker bar.
It would be helpful to spray some penetrating oil in the thread holes on the back side of the wheel.
Thanks guys. Your info. helped.
   / Rear tire flat on 2615 #5
I know that your tire fix is a done deal, but I keep a large air tank in my garage that when filled holds 120 lb of air. If I have a flat in the feild I just fill that thing and haul it out to my tractor and fill the tire enough to limp back to the garage were I can remove the tire with a impact wrench. It sure beats wallowing around on the ground. Jim
   / Rear tire flat on 2615 #6
i have the same thing - small air take - cost about 10 bucks - i also keep a can or two of the slime fix a flat stuff too
48" Pallet Forks  (A52384)
48" Pallet Forks...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
Club Car Electric Golf Cart (A51694)
Club Car Electric...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
