Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #1
michael chito
99 l42 kubota
R rear bolts on my 99 l42 threaded or pressed in both bolts hsv snapped off ???
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #2
Are you talking (wheel) lug bolts.... If so adjacent bolts/studs should give you a clue....
IF you have lug nuts on threaded studs showing then studs are pressed into flange on axle, if you have bolt heads (no threads showing) then the lug bolts are threaded into flange on axle....
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #3
For cars, I don't think I've ever seen wheel studs threaded into the hub.
However, if you can see the back side of the hub/flange, if the stud is pressed in, you'll see a mushroom head on the back side that is larger than the actual bolt diameter. And no flats or Torx for any type of wrench.
A Caliper would tell you the answer very quickly.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #4
What model of tractor do you have? L42 is not a valid Kubota model. Once we have a correct model we can provide pertinent advice. If you have a nut on the outside then the fastener is a stud and they are press fit in. If they fastener on the outside is a bolthead then they are lug bolts and are threaded in.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #6
VW does that. I think some other German cars do as well. It's kind of a pain when you're mounting a wheel.
My Kubota B7100 had a mix of bolts and studs on the front hubs, from the factory.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #7
Eartly VW (Beetle, Ghia, Thing) does not use wheel studs VW uses bolts, if there are stud in early VW hubs they are after market and are not a standard feature...
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #8
I think you are confusing bolts and studs. Most German cars use bolts threaded into the spindle instead of lug nuts on studs, but the studs are not THREADED into the spindle, they are pressed in from behind. The way the statement was written was a bit confusing and took me a second and a double read to realize what was being said.
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
Ford Pickup NR (A50323)
Ford Pickup NR...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
