Rear tire air pressure?
/ Rear tire air pressure? #1
SCtractorguy
midlands SC
L3240, BX2350, RTV 900
R4's on an L3240
I put the pressure to 12 psi. on my L3240 I can't find a listing of what it should be. I also check the fronts and they are at 30 psi :confused:
any input?
thx~!
/ Rear tire air pressure? #2
I also have a L3240 but with turfs. I use the max listed on the sidewall especially on the front tires for loader work and lower the PSI for traction depending on what I am using the tractor for. The front tires do have a higher PSI rating than the rears. The rears essentially are the tractor suspension so it is probably good that they have a lower PSI rating.
/ Rear tire air pressure? #3
Per page 71 in your manual. Front, 10-16.5, 20 psig. Rear, 420/70-24, 20 psig. Philip.
