Mar 25, 2020 / Rear stabilizer bracket XR4046 #1 C coonass39 New member Joined Feb 20, 2017 Messages 21 Location livingstom, louisiana Tractor Farmall 140 The stabilizer bracket bolts stripped out in my XR 4046. What痴 the best repair weld, tap, or helicoil? Thanks in advance
Mar 25, 2020 / Rear stabilizer bracket XR4046 #2 3Lfarms Platinum Member Joined Apr 11, 2017 Messages 904 Location Roy, UT Tractor LS XU6168CPS and Farmall F-20 Best bet is probably just go up a size or two, drill and tap with a quality tap and cutting oil, then use grade 8 bolts.
