Rear shackle
   / Rear shackle #1
bearcreek paul
by wilkes barre pa
mitsubishi mt16fd
Does anyone have any suggestion on how to get the bolt out. Just noticed today it was broken rusted through and my leaf spring is resting on my bed not good .
5 lb sledge didn't work I was hoping I didn't have to burn it out.
   / Rear shackle #2
I remove/free up so many things using an air chisel with a flat end punch. The vibration will work much better that raw force (sledge hammer). Some lubrication too.
   / Rear shackle #4
This works, I used it when replacing all 4 spring hangers on a ranger, though I was using a pointed end. At a certain point, you may just have to give in and sacrifice the bushing. I usually use a big drill bit (3/8 or so) and drill a few holes around just inside the spring eye. Then if you still can't get it free, follow up with a sawzall around the inside. I have a buddy that just burns them out, but that's kinda rough on the nose...
2013 John Deere 450J LT (A47477)
2013 John Deere...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
