rear remotes
/ rear remotes #11
I am in the process of doing the second remote install on my tractor. I should have pictures in a few weeks. By pulling the seat/pan and lever cover there is good access. Whats funny is the Kioti instruction say to pull the fender and remove the tire in addition. I can see where pulling the fender might help, but I will try without doing it.
I will (hope) to be installing the Kioti second kit that has the float feature on the second valve. The bobcat second valve ones do not have this feature. Kioti prices are a bit higher than Bobcat (roughly $450) for the second kit) but discounts can be found. I think my first single bobcat kit was in the $290 range, but not sure. I had the dealer install and got a steep discount on the parts . I think I covered it in my previous threads.
/ rear remotes #12
An update to this thread. The Kioti second valve kit Part number 322027 does fit and has the float feature. Just be sure the packaged valve says double acting float before buying
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
KBH Tender (A61307)
KBH Tender (A61307)
159120 (A60430)
159120 (A60430)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
2001 John Deere 6210 (A60462)
2001 John Deere...
