rear remotes
   / rear remotes #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
What size and type couplers are required for the bobcat factory remotes on the ct235
   / rear remotes #3
Dennis, how difficult is installing a couple of remotes for a tired old man?
I would like to have a couple
Also do you know how much the kit runs from Bobcat for a CT235?
   / rear remotes
so the hose would need male 1/2" flat face right?
   / rear remotes #5
Same as Kioti, right?
   / rear remotes #7
I think Daedong changed parts pricing discount to Bobcat, seems like last time I looked the 2 valve rear remote kit had gone up in price some. I think they are about same price as Kioti now, used to be close to $200 less.
It is the exact same installation as the Kioti. Take off the seat w/plate, remove 2 nuts and round flat cap on side of the 3pt case, remove the 2 studs, screw in the longer studs, slide the valves on the studs, reinstall the flat cap and nuts, connect the steel tube lines from the work ports going back to the couplers, install the control levers, start-up to test for leaks, and put seat back on. Took me about 2 hrs. if remember correctly.
   / rear remotes #8
Thank you sir!
   / rear remotes #9
Price hasn't changed as much as I thought. Individual dealer price will vary but should be able to get the 2 valve kit for $650 or little less, depending on shipping.
   / rear remotes #10
Cool
Thanks Dennis!
FUEL TANK (A50854)
FUEL TANK (A50854)
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
International 4700 Vibra Tiller (A51039)
International 4700...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
Rhino 116 Flex Wing Offset Disc Harrow - Heavy-Duty Tillage Tool - Selling Absolute, No Reserve (A51039)
Rhino 116 Flex...
