Firstly I appologize for my extreme ignorance of hydraulics. I am looking to add rear remotes to my 1700d. I am sure some of these questions have been asked before and once again I appologize. I was wondering what size high pressure hose I will want to runn from the 10 mm high pressure line in to my spool valve and will I want to run this same size line out of my spool valve back in to the 10 mm line. Also I must say thanks to the fine folks at Hoy for helping me through some pretty rudimentry questions I had for them. Great folks there. Any way one more point of question was braught up by a friend. Has any one had any issues with pressure or back flow between the three point flow valve and the the spool valve. i was told that since the high pressure flex hose exiting the spool valve is larger than the 10 mm line it runs back in to this may create a pressure problem or possibly back flow which may damage my pump. If this is the case would I use a check valve and if so where is the best placement for the check.
