Rear Remotes - Planning stages, need advice
   / Rear Remotes - Planning stages, need advice #111
Wow! what a great resource. I owe you big time! Do you hunt or fish? PM me at dirtpiranha@gmail.com
Oh no! I found a problem with reading those on line .pdfs. You advised to look for "Pipe #10" and "Pipe #60" on the pdfs on the Kubota site. However they use the same numbers (recycled) on most pages so those numbers mean A different part on different pages. I need the page identifier in order to make sense of the numbers. As an example I attached a file that is a snap shot of the image numbers list. I need the "HXXXXX" number that is at the top of the page. Example: H21002 HYDRAULIC OIL LINE (DELIVERY).
   / Rear Remotes - Planning stages, need advice #113
I don't hunt or fish, all I do is work.
Thanks though.
JJ
Hey!! We have more in common than you realize. All I do is work at hunting and fishing!!!
Buddy
   / Rear Remotes - Planning stages, need advice #114
JJ
Buddy
:confused2: Now I'm really :confused: :rolleyes:, I'm not JJ, why quote me? :confused3:
   / Rear Remotes - Planning stages, need advice #115
pdf H21500, #10 long pipe feeds the loader valve IN port.
pdf H21000, #10 from loader out/return port feeds the 3pt IN port
Different pdf's
L3240HST
The ref that MtnViewRanch posted, shows illustration H21002 #10 pipe feeds the 3pt.
#60 from pump feeds the loader valve.
   / Rear Remotes - Planning stages, need advice #118
Hey JJ
Thanks for the info! Should I expect that you don't fish too?
Buddy
   / Rear Remotes - Planning stages, need advice #119
No fishing.
Never could stand the waiting.
   / Rear Remotes - Planning stages, need advice #120
Another couple of questions.
(1) I assume I will be buying a Prince SV valve block with 4 levers to operate the rear remotes. Or a joy stick. On the Surplus Supply site they have a pulldown menu for how to characterize each SV valve body in the bank. I do not understand the definitions in the pull down menu. I realize one of the four should be a detent if I use a logsplitter, but the others for top link and tilt need to be another series and do I need to specify a float function as well? I also plan to have a down pressure/lift ram for the post hole auger. Would the tilt ram serve double duty here or do I need a second ram? How would you configure a 4 bank valve body?
(2) In an earlier discussion of the diverter/solenoid valve you wrote I need a valve in series with the diverter. Does it goe before the divertor or after? Where in that series do I install a needle valve to allow feathering? What valve would you recommend for this diverter circuit?
Thank you
John Deere 1023E (A50120)
John Deere 1023E...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
New Holland TS100 Tractor (RIDE AND DRIVE) (A50774)
New Holland TS100...
