Rear remotes/hydraulics on BX25
   / Rear remotes/hydraulics on BX25 #1
DAT
Yorktown, VA.
Kubota BX24
I’m looking for some advice/thoughts/anyone with experience on the following.
I’d like to add rear remotes to my BX25. Looking at hydraulic valve kit options from both fitrite hydraulics and summit hydraulics.
It appears one of the main differences is how the valves are actuated. With the fitrite kit there are handles used to open/close the valves. With the summit kit this is done with a switch box/solenoid set-up (this set-up might be a bit more compact as well). The summit kit with solenoid set-up saves a few hundred bucks, which is always good, but I would rather spend more for quality and functionality - especially if I’m missing a blaring difference, for example is there more hydraulic cylinder control with a manual handle vs a switched solenoid set-up.
Anyway, looking for any thoughts/advice and any references from other members who may have used either of these set-ups.
Much appreciated!
   / Rear remotes/hydraulics on BX25 #2
For reliability, manual handle is much better.
   / Rear remotes/hydraulics on BX25 #3
Fitright has ALWAYS been there for me with information, advice and service. I think his prices are not only fair but also competitive. If his price was a little higher, I'd gladly pay a bit more for the peace of mind.
Fitright, purchase with confidence.
   / Rear remotes/hydraulics on BX25 #4
At some time or other you may want to feather the hydraulic flow to the rear remotes. This is not possible with solenoid actuators.
Thanks all - I appreciate the thoughts/advice!
   / Rear remotes/hydraulics on BX25 #6
If you go with FitRite and you think you might want to put a 3rd function on the loader, talk to Brian and let him know he might be able to save you some money if you use his kit.
Polaris Ranger (A56859)
Polaris Ranger...
2018 JAGUAR XE (A56859)
2018 JAGUAR XE...
(2) AIR OVER HYD JACKS (A58374)
(2) AIR OVER HYD...
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
