Rear remotes for B7610
   / Rear remotes for B7610 #1
Yota_85
Western Mass
Kioti DK35se
Looking to purchase a 3pt log splitter for my 7610. My question is do I need to get rear remote valves installed or can I run hoses from the loader valves the splitter?
If it would work, would I need to use the loader stick to operate the rear remotes?
2nd question. Are rear remote valves "active" all the time? Unlike the main valve that requires a loader stick movement to activate the appropriate valve?
Seems as though this would be the way rear remotes would work.
   / Rear remotes for B7610 #2
See these posts for the hydraulics for my 3 point splitter on my 7510. First ran rear hydraulic lines (like those for a BH) for a splitter, then 6 mo later installed rear remotes and kept the rear lines for the splitter..
The feed lines are always active. ie fluid runs thru them and the splitter when connected. the must be connected together to create a complete loop, when the splitter is not installed...
I did all my own install. pretty straight forward
http://www.tractorbynet.com/forums/kubota-owning-operating/138537-log-splitter-connections-2.html Page 2 has all the pics and info...
http://www.tractorbynet.com/forums/...ng/139050-rear-remotes-finally-installed.html
Let me know if you have anymore questions..
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
3in Poly Pipe (A49461)
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
