Rear remotes for 7520
/ Rear remotes for 7520 #1
MtnViewRanch
Elite Member, Advertiser
4000\' mountains of Southern California
Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Mahindra dealers, would any of you know if there are additional rear remotes available? If they are, could you tell me what I should expect to pay?
Thanks in advance for any info /forums/images/graemlins/smirk.gif
Brian
/ Rear remotes for 7520 #2
rear remotes usually run about $200-250 per stack
/ Rear remotes for 7520 #3
RedRiver, It sounds like you might be a dealer like me. If you can get the 3rd remote kit for anywhere near that price you need to give me a copy of your special price book, or order me a few /forums/images/graemlins/crazy.gif The third remote kit has the spool valve, linkage, hard plumbing and quick connects, and if memory serves me right it is closer to $750, plus labor to install.
/ Rear remotes for 7520 #4
You are correct. I for some reason was thinking about the 00 series.
/ Rear remotes for 7520 #5
I own an 00 series, '05 5500 fwd, that did not come with rear hydraulics. What do you mean by $250 a stack? I just had dual rear hydraulics installed at a cost of $850.
/ Rear remotes for 7520 #6
Brian, I checked my price book and a third set of rear remotes are available and MSRP on the set is $887. That doesn't include instalation and different dealers may discount that price a little. Good Luck!
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
585-343-0770
Galen, thanks for the info on the 3rd remote. I'm not sure what I'm going to do yet. /forums/images/graemlins/confused.gif I've been thinking that I should probably install 2-3 more so that I won't have to disconnect the T&T when using other implements that require multiple controls.
Thanks anyway /forums/images/graemlins/smile.gif
Brian
/ Rear remotes for 7520 #8
Brian, I wonder what the record is for remotes? If you do a 3 spool, you'll have 5. Not many have more than that. I'm teasing a little, but I think I agree with you. Run another spool valve. Take care.
Dave, I went down to the Imperial valley back in December and was looking at some of the biiiiiiig tractors /forums/images/graemlins/shocked.gif that they have down there. I'm not sure, but I thought that I had seen 1 or 2 tractors with 6-8 rear remotes. Those things are giant, but when your pulling implements that are 40' or bigger and do multiple tasks at the same time, they have to be. Just my impression. /forums/images/graemlins/smile.gif
Brian
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
