Rear remotes for 5240
   / Rear remotes for 5240 #1
Buppies
Super Star Member
SouthWestern Virginia
Kubota L5240 EX mark 60 in 29 hp Toro 60inch Z Master 21 inch walk behind Polaris 900 hunter edition 30in toro walk behind
Strongly considering adding three rear remotes to my 5240. How should each one be set up? Strongly considering TNT and for third one angling blade among with other implements that require hydro hookup
   / Rear remotes for 5240 #2
One spool open center.
One spool with float.
One spool with detent for log splitter or a constant source of fluid such as an auger, hyd bush hog, hyd pump, etc.
Thanks that's how I'll order them
   / Rear remotes for 5240 #4
The first one will have to be a double acting, the second and 3rd can be whatever you want. I agree with JJ a float would be a good second remote and probably for the 3rd. It would work nice for a sidelink. I don't think you can get a remote with detent so it is always on.
   / Rear remotes for 5240 #6
Yes, you can get a three position detent with a stacked valve spool.
This three spool valve will give you detent float on one spool and detent option on another spool.
Surplus Center - 3 SPOOL 25 GPM PRINCE RD532GCCGAA5A4B1 OC VALVE
Surplus Center - 660150002 3-POS DETENT KIT RD5000 VALVE
I think that the OP is going to get his remotes & valves from Kubota.
I personally would get all 3 with the float function, but get at least 2 of them with the float function. You have a choice of double acting and float detent with the float function costing an additional $62 per valve. ;)
Kubota list price for the 3 valves, all with float function is $1902. Complete top & tilt kit from me would be $585 + shipping costs.
   / Rear remotes for 5240 #7
If Brian's kit includes all this, then he has the better deal.
If you select all three spools with float, this is your cost for the valve from Surplus.
Need hoses , fittings and some QD's.
CONTINUE SHOPPING | CLEAR CART
Description
Each Price Stock Status Qty
Total Price
3 SPOOL 20 SERIES PRINCE STACK VALVE POWER BEYOND
Item# 9-20-3-Y
Components:
- 20 SERIES DA WORK SECTION W/DETENTED FLOAT #20W D SECTION
- 20 SERIES INLET SECTION W/2200-3000 PSI RELIEF #2012J
- 20 SERIES OUTLET SECTION W/POWER BEYOND #20E22
- 20 SERIES 3 SECTION BOLT KIT #660402003 $683.80 in
$683.80
Subtotal
$683.80
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2010 INTERNATIONAL DURASTAR 4300 CARGO TRUCK (A50854)
2010 INTERNATIONAL...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
BLAST SHIELD (A50854)
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
