rear remotes for 3038e
   / rear remotes for 3038e #11
Should the potential for heat buildup be a consideration when using outboard hydraulic equipment? The 3038E only has 5 gallons or so in the tranny/hydraulic system & even small log splitters have 8+ gal resevoirs, 25+ gal on the larger ones ...
Nick
   / rear remotes for 3038e #12
Thanks for the good info. I have an occasional need to test a device using a hydraulic motor, and would like to use the hydraulics on my 3032e. Since it's occasional, can I just add quick disconnects to my existing circuit near my loader control valve?
   / rear remotes for 3038e #13
Yes, that's fine.
   / rear remotes for 3038e #14
If you install QD's before the loader valve, install a relief valve on the pump line before the QD to protect the pump in case you forget that the pump is pumping all the time the engine is running.
   / rear remotes for 3038e #15
That's a good point. I plan to put the QD's after the loader valve, and am hoping I can use the loader valve to throttle the hydraulic motor. I guess as long as I have a pressure and return line just like on the loader cylinders, it should work. Thanks guys-
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
New Swict 84" Skidloader Bucket (A50775)
New Swict 84"...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55218)
Galvanized...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2010 International Prostar (A47477)
2010 International...
