Rear Remotes and Other Extras
   / Rear Remotes and Other Extras #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
I have a few questions about rear remotes and other extras for tractors. I have been looking in the NH TC29/33D range of tractors.
* What are rear remotes and what would they be used for?
* How many should you have, if any?
* How much do they add to the cost at time of purchase?
* In purchasing a tractor, what are some other useful extras to consider? I have a list below, am I missing any?
Extras:
- Rear Remotes
- Block Heater
- Chain Hooks on FEL
- Rear Work Light
- Shop Manuals
- Extra Set of Filters
- Cutting Edge for FEL Bucket
- Teeth for FEL Bucket
- Quick Attach for FEL Bucket
- Reese Hitch for Bucket ??? ... which brings me to my next question.
* Has anyone ever used their tractor to move large boat trailers, etc.?
* If so, have you put the hitch on the front or rear of the tractor?
* If front, would it be better to attach it to the tractor or to the FEL?
Thank You,
Neo
   / Rear Remotes and Other Extras #2
Some wood splitters will use a rear remotes. I don't know what part of the country you are from but in my area I have gotten various quotes of about $300 for a set of remotes. Griz
   / Rear Remotes and Other Extras #3
Neo,
You keep posting them, & I'll keep answering them...sometimes correctly. /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( Rear Remotes )</font>
Rear remotes are necessary for hydraulically operated rear implements, such as a stump grinder that you would need to need lift, rotate, or even use the hydraulics to provide the rotation. The remotes should be $500-$1000 depending on how many you need.
</font><font color="blue" class="small">( Block Heater )</font>
Depends where you live and where your tractor is stored. I live in MD, and most folks would say that I don't need one, but if it is parked outside and it is below freezing, the tractor will start much easier & run much more smoothly if a block heater has kept the engine warm.
</font><font color="blue" class="small">( Chain Hooks on FEL )</font>
Yes, definitely. They come in handy quite often. I usually use them to secure my MMM in the bucket when transporting it.
</font><font color="blue" class="small">( Rear Work Light )</font>
Don't have one, but I wish I did. Several TBNers have put them on and a search of old posts should give you a pretty idea of how they work. If you plan the use the FEL to move snow, you should consider forward facing lights on the ROPS.
</font><font color="blue" class="small">( Shop Manuals )</font>
The manauls are pretty pricey ($100-$200), but if you plan to own the tractor for a long period of time and like doing your own maintenace or trouble shooting then they may be worth it.
</font><font color="blue" class="small">( Extra Set of Filters )</font>
If you plan on doing your own maintenance, then you might be able to get some extra filters from the dealer at the time of purchase at a discount.
</font><font color="blue" class="small">( Cutting Edge for FEL Bucket )</font>
I'm not 100% sure what a cutting edge is, (O.K. I don't know everything.) but I would recommend getting the heavy duty bucket which has reinforced edges.
</font><font color="blue" class="small">( Teeth for FEL Bucket )</font>
Teeth for the FEL are useful if you want to use the FEL for digging. I don't have them, but I'm not digging...but maybe the misses will want a swimming pool someday, and then it's backhoe time. /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( Quick Attach for FEL Bucket )</font>
They are very handy if you have other attachments for the FEL or have space limitation that calls for the removal of the bucket.
</font><font color="blue" class="small">( Reese Hitch for Bucket )</font>
Not 100% sure what you are talking about here, but moving a boat shouldn't be a problem. I don't think the FEL arms would be ideal for attaching a hitch, it's the weakest link. I believe mounting a hitch to the back of the tractor would the best for towing.
Finally, if you live up north and plow your own snow, I would recommend have the dealer put F200 hydraulic oil in the TC. There is a tendency for them to whine while they are cold, the F200 oil will lessen the noise.
Getting 50hr maintenance as part of your purchase deal is usually a good idea, this spares you some sticker shock a little ways down the road.
Big Dave,
Thank you for taking the time to answer my, more than likely, silly questions.
* What dictates how many rear remotes you need?
* How many would you recommend, if any?
The Reese Hitch I was talking about is just like the 2" receiver you see on the back of most trucks that take 1-7/8", 2" or 2-5/16" balls or pintle hooks for trailers. I was thinking about welding a 2" Class IV Reese Receiver tube to the top of my FEL Bucket so I can interchange the ball mounts and pintle hooks that I use on my pickup truck's Reese Hitch. The thinking being that it is easier to park a trailer if the tongue is attched to the front of the tractor. You can see what I'm talking about at the link below.
Reese Products
   / Rear Remotes and Other Extras #5
<font color="blue">* What dictates how many rear remotes you need? </font>
You can get 2 rear remotes on a Class II Boomer. The first one is $230 just for the parts. The second is $210 for the parts. My advice...Get at least one, then you will have it for a hydraulic toplink which makes adjusting the toplink a breeze. Wish I would have gotten one for my tractor at purchase time. I have the parts sitting here waiting for me to install them! /forums/images/graemlins/cool.gif
   / Rear Remotes and Other Extras #6
I'd say get at least one remote valve.
Not sure if the hitch would work mounted on top of the bucket. Why not bolt it instead of weld it to the bottom?
   / Rear Remotes and Other Extras #7
</font><font color="blue" class="small">( Has anyone ever used their tractor to move large boat trailers, etc.? )</font>
What do you consider "large"? I know one boat dealer who uses a John Deere 4100 to move boats and trailers around on the lot and in and out of the shop for service. I know another one who uses a Kubota B7100 for the same purpose. And I've moved one of my brother's and a son-in-law's boats around my property with a Kubota B7100 and a B2710. In all of those cases, the hitch ball was mounted on a drawbar on the lower links of the 3-point hitch because it's quicker and easier to hook up and unhook without raising and lowering the tongue jack.
   / Rear Remotes and Other Extras #8
"What do you consider large" and is it on any kind of slope might be a very big part of that decision.
Toothbar: very good useful tool.
Rear hydraulic outlets/ inlets or remotes: very useful especially with a hydraulic top link (a hydraulic ram in place of the threaded contraption tractors come with) for the box scraper, mower etc.
Cutting edge: not that big of deal unless your dragging it around on asphalt moving snow a lot.
Rear work light: easy to do yourself if your neighbors don't mind you running it around at night. Seems to be a popular thing for folks back East being as how you guys need to move snow around at all hours.
Loader bucket hook(s): of course, you will use them sometime for something. Typical use is picking up things or strapping an item to large to fit in the bucket. (see photo)
Rat...
   / Rear Remotes and Other Extras #9
I have one pair of rear remotes on my L3010 and use it (a lot) to change the angle of my rear blade (without leaving the seat) while plowing snow in winter. It also helps when doing driveway maintenance or when crowning the road. I also use the rear hydraulics to power my backhoe, as I did not want to use a PTO powered pump.
Other points:
Block heater: You live in Maine. Get one.
FEL hooks: Indispensable
Cutting edge: Why?
Tooth bar: I use my FEL for smoothing and leveling, so don't have teeth. I use the BH for digging.
Manuals: If you intend to do more than routine maintenance yourself, yes
Extra filters: Try to get this or the 50 hour service as part of the purchase package. Also try for pickup and delivery of the tractor for service.
Rear light: Handy in winter for moving snow. A pain in summer as they attract any bug within 50 miles! /forums/images/graemlins/shocked.gif
Best of luck, neighbor! Pete
   / Rear Remotes and Other Extras #10
On your boat quuestion, I use my BX2200 to move anything I can hook up to.
I move my 3000 lb sailboat boat with a ball hitch on a cross drawbar and sometimes use the FEL for smaller boats.
See photos
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
2016 Toro Pro Force Towable Blower (A50322)
2016 Toro Pro...
1998 SPARTAN MOTORHOME CHASSIS (A50324)
1998 SPARTAN...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
