Rear Remote
/ Rear Remote #1
hagman
Central, IL
B7610 Kubota
Hello All,
I am going to show my stupidity here but I keep seeing references to "rear remotes". Can someone explain to me what they are and the use of them? Thanks to all that reply.
/ Rear Remote #2
Hyd remote connectors and spool valves mounted on the rear of the tractor for use in running external hyd cyl's and motors. For example, my Nh 7610s has 2 rear remotes and valves. I use 1 remote to lift the tail wheel on my 15' batwing mower. I use the other remote to fold the wings on the batwing mower. etc.
Same would be true of a disc with transport wheels or wings.. etc. Lots of uses for external hyds.
Soundguy
/ Rear Remote #3
Another use, which I want but haven't got yet, is replacing your top link with a hydraulic top link. You'd need a rear remote to operate one of those too.
/ Rear Remote #4
With some extra plumbing those same valves can control things mounted on the loader like a grapple on the bucket. I have 2 circuits brought forward to control a grapple or alternately a tree shear; 1 to open/close and the other to rotate the shear head horizontal/vertical.
Vernon
/ Rear Remote #5
here is a pic of 3 rear remotes on a New Holland TN70A ag utility tractor.
One of the three sets is being used.
/ Rear Remote #6
Here's what 3 rear remotes look like on the back of my TC-40D SS. One set operates the hydraulic top link, one set operates the hydraulic side link, and the 3rd set remains open for other needs.
/ Rear Remote #7
You sure about that ? ..... looks to me like two are in use and one set is open ...... :D
/ Rear Remote #8
Here's what my rear remotes look like on my Kama 554. I made the bulk head fixture for the 3 sets and place them in an easy to get to position. They are easily accessible even with any implement on the 3pt.
/ Rear Remote #9
Yes, I was in a hurry and did not pay attention. Oops!
Bob
/ Rear Remote #10
I have a TC45 and it looks a lot like Pineridge's pic .... I had 1 set installed when I bought the tractor -- a 2nd set later ... and wouldn't mind having a 3rd ... moral - you seemingly can never have enough. They are so-o-o handy. I use the 2 I have for 1. hyd toplink (which never comes off) and 2. front grapple ... eventually I know I'll be getting some attachment that will require a third of some sort - "WILL IT NEVER END?" (quote from the wife):rolleyes: :D ..... but then she's the one that wants a backhoe --- go figger
/ Rear Remote
Thanks to all that replied to my inquiry. Since I'm still relatively new to tractor ownership you can expect to see more questions as time goes on. TBNers have to be one of the most informed and helpful people out there.
Hagman
/ Rear Remote #13
Not to throw a damper on the enthusiasm for rear remotes, but I have a set on my DX29 that I haven't used. What I have used is the branch circuit from those lines that runs to the front and operates the grapple I added to the bucket. Even if I never take the caps off the rear lines, the utility of having the bucket on the grapple more than compensates for the extra cost of getting the rig set up when I ordered the tractor.
/ Rear Remote #14
No top and tilt on your rig? :confused:
/ Rear Remote #15
MIKIM, How did you ever find a wife that wants a backhoe? Does she have a sister?:) :)
/ Rear Remote #16
Mine have not been unplugged since the day I put them on........hydraulic top link is sweet :D
New/Unused ATS Mini Excavator (A65583)
New/Unused ATS...
Crust Buster 15ft. Grain Drill (A65640)
Crust Buster 15ft...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
