Rear Remote Pressure Question
   / Rear Remote Pressure Question #1
Haoleguy
Platinum Member
SE Connecticut
JD 5325; Landini Mistral 50
I'm in the process of purchasing a hydraulic tool that is rated for a working pressure of 1500-2000psi. I'm looking to plug this into one of my rear remote sets. I have not yet tested my rear remote hydraulic pressure yet but I believe it will be in the 2200-2300 psi range based on discussion with mechanic familiar with my tractor(Landini Mistral). If it is indeed higher than the tool operating pressure range how is it best to reduce this pressure to 1900-2000 psi?....Thank you, Gary
   / Rear Remote Pressure Question #2
Thank you JJ that's what I was thinking might be the answer. The valve that I saw that is preset for 2000 psi is the following..... Surplus Center - WJL-50-2000 HYD RELIEF VALVE . Any difference in preset relief valves versus dial in the pressure in terms of reliability? Thank you again......Gary
   / Rear Remote Pressure Question #4
No, the factory just has a set number they use for a type of valve. They usually indicate the adj psi range.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2017 Ram 5500 Crew Cab Reading Service Truck (A52377)
2017 Ram 5500 Crew...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
