Rear Remote Kubota L39
   / Rear Remote Kubota L39 #11
Yes, 12v and six hoses, Here are the instructions.
https://www.surpluscenter.com/Instruct/I9-5117-A.pdf
There are other selector valves that will handle more GPM's, but of course the price goes up.
You could mount a switch handle on that lever for operating the thumb.
You could also rig it so the thumb is on and the stabilizer is momentary.
   / Rear Remote Kubota L39 #12
I know this is an old thread but I like this idea. Seems pretty simple. I plan to add a thumb to my L35. Using this setup for the thumb do I need to worry about pressure relief? Could the curl of the backhoe bucket against the thumb cause too much pressure for this circuit?
Also, is there a manual valve version of this so I wouldn't even have to run wires?
To the original poster, what did you end up doing and how did it work out?
   / Rear Remote Kubota L39 #13
My L35 has a foot pedal to operate the thumb and a relief valve on the thumb hydraulic line. I believe that the foot pedal is a Kubota stock item. Unfortunately, I don't know enough about hydraulics to tell you how to plumb it in to the curl line but I am sure that if JJ chimes in that he can help you. There are no electrical lines on my setup.
   / Rear Remote Kubota L39 #14
Do you have a valve to operate the thumb?
Just match the valve GPM with BH supply GPM
In order to protect the thumb cyl, you need a relief across the thumb cyl.
   / Rear Remote Kubota L39 #15
No, I don't have a valve yet. What I was saying was that I liked your idea of using one of the stabilizer valves and adding the solenoid valve you suggested (or a manual version of it). To me this seems simpler than a new valve and worrying about power beyond and the return and all that, but maybe I am mistaken? If I were to do this, using the stabilizer valve and the solenoid valve would I still need to worry about relief or is that already built into the stabilizer valve?
   / Rear Remote Kubota L39 #16
The BH should have it's own relief while using the cyl.
When the valve spool goes to neutral, flow is blocked , so you will need work port relief for the thumb.
With a manual valve, you need the PB unless it is the last valve in the series path.
Hyd subplates port are all high pressure.
Either way, you need the relief valve across the cyl.
Some valves have work ports reliefs.
   / Rear Remote Kubota L39 #17
J_J, with that 14gpm valve you suggested, it says I need an additional part, the power beyond sleeve, to have power beyond or closed center. It appears that my backhoe valve bank does not have any power beyond port so I would need to add this valve in before the main valve bank. Forgive my lack of knowlege, but for a thumb I believe I want a closed center, correct?. I would also need the power beyond to feed the main valve bank. So will this valve work, and do I need to buy two sleeves to have both power beyond as well as closed center? This is all new to me so any help is greatly appreciated.
Also, do you see any problem adding this in before my main valve bank? I guess the pressure would run through the valve to the power beyond and I would just have to tee together the return.
I also just noticed that the page for the power beyond sleeve states "Power Beyond:
Allows oil flow to a down-stream valve while first valve is in neutral position. Outlet port of first valve must be plumbed directly to reservoir." I am not sure exactly what this means, I guess while I was moving the thumb all my other functions would be dead?
I just want to make sure to order the right stuff, I see Kubota sells a kit which I just priced at $1750 from the dealer...way too steep! (I wondered if maybe it included the thumb, but no!)
Thanks,
Steve.
   / Rear Remote Kubota L39 #18
You don't need closed center for anything.
You need the PB sleeve to connect to another valve downstream.
If you are using a BH right now, and it is working good, then it must be sending high pressure downstream to the 3pt.
A thumb can use hyd from several different sources.
A valve upstream of the BH with PB.
A diverter valve using one of the stabilizer spools. Default would be stabilizer, and when you select the button on the stabilizer lever , the thumb would operate. You need a relief valve across the thumb cyl.
A true 3rd function using a solenoid valve upstream using a thumb switch on one of the levers.
You should be able to do a thumb control for about $200.
There are certain situations where you may lose hyd flow downstream.
During the time the 3rd function is being used, the flow downstream is coming from the hyd cyl or hyd motor the 3rd function valve is controlling.
If you are using a lever valve for the thumb, and only use half lever, you still have about half flow for downstream use.
All OUT ports should go to tank.
   / Rear Remote Kubota L39 #19
Thanks J_J and all. So I ordered everything I need, I think, including 14gpm valve, pb spool, lots of extra fittings, and 4 hoses for under $275. Much better than $1,750! Once I get it all figured out an working I'll post part numbers for what I used and how it worked out.
   / Rear Remote Kubota L39 #20
Darn, I got notification that the power beyond sleeve for that 14GPM DA valve is backordered. I was going to put this valve prior to the main bank on the backhoe. I really wanted to get this thumb installed to play around with it while I am off from work this week. Does anyone know any workaround? I know this is probably a newbie question, but why can't a valve like this just be T'eed into both the pressure and return lines going to the main valve bank on the backhoe? Would this work?
Thanks,
Steve.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2015 Kubota MX4800 4WD Tractor with LA1065 Loader Backhoe (A55787)
2015 Kubota MX4800...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
2012 Cornhusker800 43ft Hopper Trailer (A55301)
2012 Cornhusker800...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
