Rear remote kit
/ Rear remote kit #21
That's a pretty good sized backhoe for that tractor. I recommend you get a sub frame for it.
A Kioti or Rhino sub frame should bolt up to that hoe.
Tony and Vince,
I appreciate the info and advice. Mine has got a subframe with it already and my friend is working on fabricating the subframe tobfit my mounts. If this hadn't come with one, there's a good chance I wouldn't have known about them so thanks for looking out for me!
Shared album - Jamie Noe - Google Photos
Mals
/ Rear remote kit #22
Tony and Vince,
Mals
Good that you're getting a subframe. I know the CK manual specifically says not to use a 3PTH BH. It just puts too much strain on the hitch.
/ Rear remote kit #23
Do you have the part number for the kit? I called a Kioti dealer and was quoted about $850. Now I'm a little outside my comfort zone when talking tractors and I don't know exactly what I'm asking for, so I may have said something wrong... Thanks in advance,
Mals
Try calling a Bobcat dealer and ask for P/N 7150493. This is the 2 remote valve kit that fits CT230/Kioti CK30. List price is around $600 + shipping. Closest Bobcat dealers are in Oklahoma City or in AR - Fort Smith, Fayetteville, or Rogers
/ Rear remote kit #24
Go here Michigan Iron and Equipment, Kioti Tractors, Kioti Implements, Kodiak Attachments, Befco, Hound Dog Attachments, Dk Series Tractors, Central Michigan and look up the parts online.
OEM Parts
Shop around - the best pricing on a valve group I found was in Southern California using the Kioti dealer search and parts number search. Look up my old threads on my second remote install as I give the detailed information and parts numbers
I recommend getting both remotes the second set has a float function - at least it did. I installed the second Kioti set on my Bobcat so I know they will fit Bobcat too.
/ Rear remote kit #25
Not sure if they are very similar, but the dual rear remotes kit from my Kioti dealer was $350, installed myself. I had just bought a tractor, so maybe it was cheaper? Kit installs well, very tight fit but looks clean. I had to retorque one of the hydraulic fittings going into the tractor, so good'n-tight on those banjo bolts. But don't use a long ratchet driver, and snap one of those banjo bolts in half, like me..
AGT Industrial SSECAG-Y QA Auger w/ Bits (A60463)
AGT Industrial...
2020 DRAGON ESP...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
AgriLifter Load Lifter 5000 (A60462)
AgriLifter Load...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
