Rear Remote Kit for B7510
/ Rear Remote Kit for B7510 #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
Looking for the Kubota Part number for the Rear remote kit for a B7510?
Also interested in hearing any comments from anyone who has installed the rear remote kit on a 7510 or a 7610.
Stu
/ Rear Remote Kit for B7510 #2
Stu:
I have the factory remote on my 7610. Don't have part numbers but the dealer had a hard time finding it. He also installed and I did it when I bought my tractor. I like it, thought it was going to be in the way but its been over 3 years now and I'm used to it. Only one spool and is dedicated to hyd. top link. I do have a loader, joystick valve sitting on the shelf and thought of replacing it to get 2 spools going but hasn't been needed so far. Probably quite expensive to purchase outright as others have just went with non-oem valves for 1/2 to 3rd of oem. Check out some of the old MadRef posts as there is a ton of detailed info in them.
Here is a thread that has pics of the Kub setup.
http://www.tractorbynet.com/forums/kubota-owning-operating/39428-7610-rear-hydraulics.html
Regards,
Kevin
Thanks Kevin!
Just trying to get some numbers to determine when I get my grapple if I want to go with it operating off a rear remote, or a diverter valve like the WR Long style.
Stu
/ Rear Remote Kit for B7510 #4
This is a generic rear remote kit that Kubota seems to sell for all models that don't have a REAL factory rear remote kit - including the L2800/L3400.
I was a bit dissapointed that this is the only 'factory' setup available from Kubota when I saw what the setup was like on the Kioti CK20/25/30. They have nice hard lines that go to the rear - not mounted on the ROPS.
I do like the fact that the Kubota 'kit' has a nice mount for the ROPS so one does not have to come up with a way to mount an aftermarket one.
The price of the first spool is fine IMHO since it includes the mount etc. However additional spools are a ridiculous price (~$250).
/ Rear Remote Kit for B7510 #6
I've got the exact same setup on my B7610 that khd pictured on his 2004 thread. I wasn't as smart about it as he was and paid way too much for it. It does stick out too far to the right and I tore the bark off a tree and scraped some paint off my boat before I got used to it. Since then, there haven't been any incidents.
Mine developed a problem early on because the fitting block, that attaches to the side of the transmission case to tap a hydraulic port for the remote, wasn't made right. A leak developed that kept the top of the mower deck a mess. The dealer replaced the block under warranty and all's been well since.
The remote has not seen any use to date. I originally got it with the idea of using it to power a dump wagon. However, I've yet to find one that's really suitable for this sized rig. May have to try to build one. Other than that, I might eventually get a hyd. toplink. If I had it to do over, I'd skip it entirely. It's the one bad decision I made on the 7610 buy.
Bob
A couple of other questions for those that have installed a rear remote.
How/Where do you tap into the tractor for hydraulics?
Do you use the 2 extra fittings on the block outlet cover?
I take it if I am going to install a HTL or Grapple, and use the rear remote that I don't need to tap into the return port on the side of the transmission?
Stu
/ Rear Remote Kit for B7510 #9
Here is a crude diagram to give you an idea of how to add a remote;
  • Adding a remote.pdf
PSDawg,
Thanks for the drawing!
I was wondering if you had a list of material you used to put together the hoses and fittings for your HTL cylinder?
I also sent you a IM.
Stu
/ Rear Remote Kit for B7510 #15
Very nice setup. Thanks for the link.
/ Rear Remote Kit for B7510 #16
Stu
The P/N for the Rear Remote Hydraulic Kit is B7333.
This is for all B7300,B7400,B7500,B7410,B7510, AND B7610.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2004 KENWORTH 10 WHEELER GRAIN TRUCK (A64278)
2004 KENWORTH 10...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2025 24in Mini Excavator Bucket Attachment (A64553)
2025 24in Mini...
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
