Rear Remote CK 20H
   / Rear Remote CK 20H #1
Mike O
Vancouver Island BC
CK20 HST 2007
Seasons Greetings: I am having issues with the hydraulics on my 2007 Kioti CK20H; the engine starts to bog down when the Remote Control Valve Lever is in either position A or B. I forgot to move the lever back to N after using a rear mounted hydraulic implement; used the tractor for about an hour with the rear hydraulics deadheaded and the PTO engaged. Tractor started to overheat and run rough, but I caught it in time. The tractor runs fine and both the FEL and PTO implement operate ok (not using rear hydraulics) in the N position however I need to engage the B position to power the log splitter. Any ideas? Thanks.
   / Rear Remote CK 20H #2
If you have another implement or cylinder that doesn't have a separate valve I would want to see if it still loads the tractor. Might even use a hose with nothing attached and see if you are even getting flow out of the valve.
It could be something simple like a bad coupler on the tractor or splitter.
Good luck and Merry Christmas!
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
CATERPILLAR SKID STEER QUICK ATTACH PALLET FORKS (A51243)
CATERPILLAR SKID...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
