Rear Rake with Wheels & 2 Hydraulic Rams
   / Rear Rake with Wheels & 2 Hydraulic Rams #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
   / Rear Rake with Wheels & 2 Hydraulic Rams #2
Most of all rake covers your wheel track at 45 degree setting,I would lean towards 8' rake.
Thanks.
Have to dig out the Hypotenuse, Tangent and Adjacent calculator to make sure the 45* angle covers the tire width.
Never could remember those relationships...
   / Rear Rake with Wheels & 2 Hydraulic Rams #4
There is almost no limit on rake size for a 40HP tractor,,
This is my 40HP tractor with a 7' rake
Anything that tractor can do with that rake, I can do with my tiny JD 650 17HP tractor,,
The only reason the rake is ever put on the 40HP tractor is that the larger tractor has hydrostatic drive,, instead of the gear drive that the 650 has
Your checkbook is the only limitation,,,:thumbsup: :laughing:
   / Rear Rake with Wheels & 2 Hydraulic Rams #5
Thanks.
The square root of "A"squared + "B"squared = C
Ok, thanks.
Groogled Right Triangle Calculator
Did 2 widths of rake 7' and 8' as the hypotenuse.
Raked path width @45* is 5.0' for the 7' rake and 5.7' for the 8' rake
According to owners manual tractor is 62.4" or 5.2' wide, soooo, it looks like an 8' rake would cover the wheel track but if a 7' rake was a real deal, we could make do...
Headache Rack (A50860)
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
8 Ton Combo Pintle Hitch (A48081)
8 Ton Combo Pintle...
2011 Ford Ranger 4x4 Ext. Cab Pickup Truck (A48081)
2011 Ford Ranger...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2022 Club Car...
