Rear PTO Speed
/ Rear PTO Speed #1
Roadkill95
CT
none now
What is the purpose of 2 speed rear PTO? I see 540 seems standard and then I see B7610 and B7510 also have 940 or 960 can't remember. What would the higher speed be used for and does it have the same HP @ that higher speed?
/ Rear PTO Speed #2
There are situations where having different available pto speeds can be useful. On jobs that require less torque, higher-speed pto gearing lets you run the engine at lower rpm, while maintaining implement speed. My tractor has a bigger engine than is sometimes needed, so the high speed pto setting is used for several kinds of mowing - the engine can run down at 1700 or so with less noise, heat, wear - even a little less fuel. Some implements are designed for the higher input speed - although not commonly available in the U.S. I believe haying equipment in Australia & New Zealand is designed for higher input speed.
/ Rear PTO Speed
Maybe I could mount a giant fan on it so it will cool me while I shovel because if I buy a B7610 there won't be a hoe for a while:D :D :D
/ Rear PTO Speed #4
I like the fan idea. :)
Back on your question about horsepower, the HP is the same at either speed, but the available torque is less at the higher speed - its directly proportional.
This is actually a favorite subject of mine - there's a thread about adding a 2-speed pto to my tractor here.
/ Rear PTO Speed #5
Dick…
Your 2 speed upgrade looks as interesting today as it did back then… WoW can it really be 5 years ago… Thanks again for an interesting post… if I had more than 45 HP I would look into parts for the same thing. KennyV.
/ Rear PTO Speed #6
Lotsa tractors have different pto speed options.. the jap variety sometimes have 3-4 speeds. I've seen specialized tool like tillers and such use th higher speed.. especially on the yanmar units.. etc..
Soundguy
/ Rear PTO Speed #7
KennyV said:
Dick…
...........as it did back then… WoW can it really be 5 years ago… .
Geesh - I wouldn't have guessed that either - seems like a couple months ago. I better get working on something new....
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2025 Ranger 1000 XP Northstar Premium (A62679)
2025 Ranger 1000...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
3 BottomPlow (A62613)
