Rear PTO Question
   / Rear PTO Question #1
dmartin88
Leesburg, Virginia
Kubota BX22, Bobcat 763H
Just used my new Rhino 42 inch rotary mower on my BX22, also the first time I removed the backhoe! Removing the backhoe was easier than expected, hopefully it will go back on just as well.
Used the mower to cut a path through about 2 acres of woods on my property, did a great job, will go back a couple more times but a fun project so far.
My question, didn't get the book with the mower but one thing I noticed is a short "pause" before the pto/blade starts turning after I engage the drive. Gives a pretty good jerk as well. Is this normal? Hope to pick up the manual this weekend but thought it might be worth asking here.
Thanks to all who post and answer the many newbie questions like mine, this is a great resource!
   / Rear PTO Question #2
The jerk you feel is just the blades extending out from the blade holder. A short pause on that model is normal.
   / Rear PTO Question #3
</font><font color="blue" class="small">( Gives a pretty good jerk as well )</font>
I hope you are engaging and disengaging the PTO at idle speed, THEN moving up to speed. I don't know about your particular model, but many newer tractors have PTO brakes that you will tear apart if you do this all the time, not to mention the clutch.
Mark
   / Rear PTO Question #4
dmartin88
That short pause is the hydraulic independent PTO hooking up. Be sure to idle down, engage the PTO and then raise engine RPMs. Hope this helps.
Lewis
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
1995 Rinker Captiva 190 (A53473)
1995 Rinker...
