Rear PTO leaking...
/ Rear PTO leaking... #1
Bruce8989
Indiana
Kubota B5100D 4WD
My Kubota B5100 has been dry as a bone - not a leak or drip anywhere. I just hooked up rear finishing mower and find that oil is seeping out of the rear PTO, but only when the PTO is under load. What's going on here?
Thanks!
/ Rear PTO leaking... #2
I have seen this on a JD 820. hasn't been repaired yet but it looks quite easy on this tractor. Remove the cover over the PTO shaft 4-5 bolts, there is a standard seal in there that I assume becomes old or damaged. Looks to me to be an inexpensive repair if one has tools and can do it their self......I believe you may have to drain the hydraulic fluid though...that's not cheap if one has to replace what is drained out.
2004 CATERPILLAR D6R XL CRAWLER DOZER (A65053)
2004 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
More info coming soon (A64557)
More info coming...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
