Rear PTO leaking...
   / Rear PTO leaking... #1
Bruce8989
Indiana
Kubota B5100D 4WD
My Kubota B5100 has been dry as a bone - not a leak or drip anywhere. I just hooked up rear finishing mower and find that oil is seeping out of the rear PTO, but only when the PTO is under load. What's going on here?
Thanks!
   / Rear PTO leaking... #2
I have seen this on a JD 820. hasn't been repaired yet but it looks quite easy on this tractor. Remove the cover over the PTO shaft 4-5 bolts, there is a standard seal in there that I assume becomes old or damaged. Looks to me to be an inexpensive repair if one has tools and can do it their self......I believe you may have to drain the hydraulic fluid though...that's not cheap if one has to replace what is drained out.
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
JOHN DEERE CP690 LOT NUMBER 73 (A53084)
JOHN DEERE CP690...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
20711 (A50323)
20711 (A50323)
