Rear PTO just stopped!
   / Rear PTO just stopped! #1
cfdwarrior
My rear PTO on my BX2360 suddenly just stopped working! I was tilling at a shallow depth and making passes over what was my garden area, I was about to make my final pass, and when I engaged my land pride tiller (0550), the rear PTO just didn't work all of a sudden! I have only about 12 hours on this machine. Other than calling the dealer (since they are closed Sat afternoon and Sun), any ideas out there what may be going on?
   / Rear PTO just stopped! #2
hmmm, not sure of your exact tractor, is it an electric switch engaged pto? is it manual lever? are you sure a shear bolt on the pto didn't break and that the pto is actually still turning.
   / Rear PTO just stopped! #3
Probably a stupid question but did your PTO lever maybe get switched to the front PTO position? Sorry.
   / Rear PTO just stopped! #4
Nothing to be sorry about, Bro...
I don't know Kubotas, but you never know...that might be the answer.
   / Rear PTO just stopped! #5
   / Rear PTO just stopped! #6
yup - sounds like you hit the pto selector to MMM only.
If you still have a problem, then take pto shaft off and verify the rear is turning fine since the shear bolt is probably snapped on the shaft if you dont have a slip clutch.
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
