Rear pto does not engage.
   / Rear pto does not engage. #1
pkav32
Bronze Member
Massachusetts
john deere 2520
Was using the rotary cutter the other day and the rear pto did not engage. I finally put it in rear and mid together and it worked. I'm sure this is not advised but I only have so much time to get the job done. is there some adujstment anyone is aware of.
   / Rear pto does not engage. #2
You might want to include what model tractor you have. Also cab or not, on some models it makes a difference.
I have a 2520. No cab. It feels like it is engaged but it just does not turn when it hit the pto.
   / Rear pto does not engage. #4
don't know much about it but i had the same problem with my 5105 and it turned out the mechanic who serviced it before i took delivery left the linkage loose, after hooking it back up it still didnt have enough power to run the hog through thick bahia, a couple of turns on the adjustment rod cured that as well. good luck.
earl.
(INOP) KUBOTA B7510 TRACTOR (A51247)
(INOP) KUBOTA...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
(6) DRAWER METAL TOOLBOX (A51248)
(6) DRAWER METAL...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
