Rear PTO add on JD x475
   / Rear PTO add on JD x475 #1
stpgrinder
Horace ND
x475 JD
Does anyone have the part number for the rear pto add on kit for a 2006 john deere x475 garden tractor? Any information is greatly appreciated, thanks
   / Rear PTO add on JD x475 #2
The original PTO for the x4..and x5.. tractors is BM20633. It was later replaced by BM21914. The main difference was that the original BM20633 had all of the required parts. BM21914 will work on the x4.. x5.., and was used on the x7.. series early on. The x7.. series tractors had the control module, AM120840, already installed and was not needed, so it was eliminated from the kit. If you get the new BM21914, you will need to order the control module AM120840. If you can find BM20633, the module is included. There was a later PTO kit, BM23588, released for newer x7.. series after June 2010 that will not fit the x4.. or x5.. series.
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
UNUSED FUTURE EXCAVATOR COMPACTION WHEEL (A51244)
UNUSED FUTURE...
