rear PTO/3 point hitch Qs for JD 430 garden tractor
   / rear PTO/3 point hitch Qs for JD 430 garden tractor #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I have a John Deere 430 Lawn/Garden tractor with a 20 or 22 HP Yanmar diesel. I just bought a 4' MH4 Billy Goat rear brush cutter.
1) Is this enough HP to use this JD to run it?
2) What's involved to set up rear PTO/ rear 3 pt hitch. I think the rear PTO may already be there. I only ever use the mid PTO for my 60" mower deck.
Thanks all for your expert help. :thumbsup::)
I took a closer look. there is a rear PTO set back half way under the seat. There is also a PTO engagement switch on the instrument panel area.
As soon as I start tractor, that rear PTO shaft spins and the engagment switch seems to make no difference. Any ideas on that?
I see several rear 3 point hitch kits on ebay. Do I only have to add a 3 point hitch kit to be able to connect my 4' brush cutter?
Is 20-22 HP enough to power a brush hog to cut long overgrown grass? (it bogs out on my 3 blade 60" cutting deck).
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2012 Freightliner M2 106 Dump Truck, VIN # 1FVACXBS3CHBJ4624 (A51572)
2012 Freightliner...
CASE 580SV BACKHOE (A51246)
CASE 580SV BACKHOE...
Kubota B7800 4x4 Tractor (A51573)
Kubota B7800 4x4...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
1991 Ford LNT9000 Truck, VIN # 1FDYW90L5MVA15646 (A51572)
1991 Ford LNT9000...
