Mowing rear mower question
/ rear mower question #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
do rear mowers pull like a trailer (pivits) or are they rigid to the tractor like a shredder?
/ rear mower question #2
There are both kinds of rear mowers. Those who are pulled by the drawbar(flexible ?), and those who hook up to the 3 point hitch (rigid).
Ben
/ rear mower question #3
I've only used the kind attached to the 3 point, but I'd imagine the other kind wouldn't be too good for trimming arount buildings and such. Particularly if you neeed to reverse.
/ rear mower question #4
They work ok in reverse, sort of like backing up a trailer. Lots quicker/easier to hook up , just the pin and usually hydraulics to adjust the height.
Ben
/ rear mower question #5
And the PTO shaft of course.
I'm guessing that they are larger mowers used on larger tractors where the three point might not be able to pick it up anyway.
/ rear mower question #6
The 3pt mowers may or may not be rigid. Mine has swivel links between the 3pt arms and the mower. The swivel link is ~4" or so with balls on both ends just like on the 3pt arms. The top link connects to the mower deck with a chain. Between the two there is room for a fair amount of movement. These are fairly easy to back up with and manuever around.
thanks,, ive used a shredder, and a riding mower but i have never used a rear finish mower. with the shredder it comes off the ground when i top the hill on my pond **** and i dont feel comfortable going from the side with the tilt. im going to get my wife a subcompact and need to decide on a mmm or a rear finish mower.
/ rear mower question #8
Right you are the PTO shaft as well. And yes af far as I know all batwing cutters are pull behind type.
Ben
/ rear mower question #9
I just set the position control to about 5. This lets the 3pt arms drop below the mower, the links are pointing down until you start pulling the mower. I never have any lifting problems front, back or side to side.
However if mowing is the primary task then go with a MMM. Preferably one that will come off quick and easy.
/ rear mower question #10
</font><font color="blue" class="small">( im going to get my wife a subcompact and need to decide on a mmm or a rear finish mower. )</font>
If your wife drives the way mine does, you will DEFINATLEY want a MMM /forums/images/graemlins/wink.gif
/ rear mower question #11
I have a Frontier RFM. It mounts to the 3pt hitch, but the top link is left kind of loose, and the mower rides on its 4 wheels. Nice cut. I think it would handle your bank much better than a rotary cutter.
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2019 K&K Equipment Trailer, VIN # 1K9PE2026KA175452 (A65563)
2019 K&K Equipment...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
