Rear lighting on a Kioti NX with ROPS
   / Rear lighting on a Kioti NX with ROPS #1
jdeere2424
Kioti NX5510 HST ROPS
Kioti NX5510 with HST and ROPS. The rear light bulbs keep burning out and the connections are rusting. I would like to replace the whole assembly. What is a good replace product?
   / Rear lighting on a Kioti NX with ROPS #2
Dielectric grease may prevent corrosion on electric contacts, LED's should have longer life. Have you checked charging voltage? Shouldn't go over 13.5 -> 14 volts
The lights work until the bulbs get wet and burn out. I just wanted to get new lights the stayed dryer
   / Rear lighting on a Kioti NX with ROPS #4
My 2 cents.
Bulbs with filaments are very fragile.
Replace with LED's and that might fix your problem.
   / Rear lighting on a Kioti NX with ROPS #6
Are you talking about the rear work lights (add-on) or the OEM hazard/turn signal lights? If you mean the OEM hazard/turn signal lights, replacing those could get pricey. You may try drilling a small hole in the bottom of the fixture for water to get out, and seal the top with a bit of silicone caulk.
When I bought my used tractor, my lights were filled with water from the techs using a pressure washer to clean it. I drained them, used dielectric grease to prevent more corrosion, replaced the bulbs with LEDs, and parked it under a cover when not in use.
I'm talking about the OEM hazard/turn lights. I replaced the clear bulbs with LED bulbs. The colored bulbs aren't a 180 degree offset, so I wasn't able to get the right ones.
I would like to get the front clearance/turn signal also but couldn't the number.
Does any body know where I can get a parts catalog?
John Deere 7H19 (A56469)
John Deere 7H19...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
2018 International DuraStar 4300 26FT Box Truck (A55852)
2018 International...
2005 Chevrolet Colorado 4x4 Pickup Truck (A55852)
2005 Chevrolet...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
