Rear lighting on a Kioti NX with ROPS
   / Rear lighting on a Kioti NX with ROPS #1
jdeere2424
Kioti NX5510 HST ROPS
Kioti NX5510 with HST and ROPS. The rear light bulbs keep burning out and the connections are rusting. I would like to replace the whole assembly. What is a good replace product?
   / Rear lighting on a Kioti NX with ROPS #2
Dielectric grease may prevent corrosion on electric contacts, LED's should have longer life. Have you checked charging voltage? Shouldn't go over 13.5 -> 14 volts
The lights work until the bulbs get wet and burn out. I just wanted to get new lights the stayed dryer
   / Rear lighting on a Kioti NX with ROPS #4
My 2 cents.
Bulbs with filaments are very fragile.
Replace with LED's and that might fix your problem.
   / Rear lighting on a Kioti NX with ROPS #6
Are you talking about the rear work lights (add-on) or the OEM hazard/turn signal lights? If you mean the OEM hazard/turn signal lights, replacing those could get pricey. You may try drilling a small hole in the bottom of the fixture for water to get out, and seal the top with a bit of silicone caulk.
When I bought my used tractor, my lights were filled with water from the techs using a pressure washer to clean it. I drained them, used dielectric grease to prevent more corrosion, replaced the bulbs with LEDs, and parked it under a cover when not in use.
I'm talking about the OEM hazard/turn lights. I replaced the clear bulbs with LED bulbs. The colored bulbs aren't a 180 degree offset, so I wasn't able to get the right ones.
I would like to get the front clearance/turn signal also but couldn't the number.
Does any body know where I can get a parts catalog?
UNUSED FUTURE EXCAVATOR COMPACTION WHEEL (A51244)
UNUSED FUTURE...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
2010 GMC Acadia SL SUV (A50324)
2010 GMC Acadia SL...
