Rear Lift won't drop
   / Rear Lift won't drop
I realize not many people here could give a hoot as to the dilemma I've having with my tractor, and seems as though I'm just top posting :( but their have been many reviewing this thread so for those who are interested and might be having similar issue here is where the hydraulic problem stands,
I manage to disassemble the parts from inside the piston, the plunger actually pulled out with a bit of extra force, The spring,ball & ball Carrier came out, nothing looks bad or pitted on these parts... thee 2 small pc of what I thought was a broken C-clip was actually made this way and slip in along the side of the plunger to hold it inside the piston, so I put it all back together and the tractors lift now worked better than ever and will stop and hold at every increments of where I set the lever, I use the harrows again for 40 minutes and all seemed to work great, I then start using the FEL for 10 minutes to back drag and went to change out implements and realized that the harrows was stuck way up again and would not lower, Oh well! back to the drawing board:cool: At least I know how to go through this part with my eyes closed, should I try replacing this? where can one be purchased?
Thanks folks
   / Rear Lift won't drop #12
I think every one reading this likes to hear out come of problem. Is your 3 point and fel valving tied together? Do you think the 3 point hyperextended again? When you get it down again try putting 3 point down as far as it goes, then work fel pretty good while watching to see if 3 point starts drifting up.
   / Rear Lift won't drop #13
Hi Deepndirt,
I am quite sure most people do in fact give a hoot but just don't have an answer for you. I know I have read your thread a few times and have no idea of how to help ( but am looking forward to the resolution).
If you check in the Yanmar category you will probably find a few dealers that will be able to help out with parts etc. I know that is LMTC and a few more that try to help.
Good luck and please let us know how you make out.
   / Rear Lift won't drop #14
Thanks folks
I for one am interested in the outcome, went to lower the rake on the Case and to my surprise it will go up and not down, so I would like to here what you are doing. May help my situation? Good Luck::thumbsup:
19009 (A48082)
19009 (A48082)
2025 John Deere 335 Track Loader Skid Steer (A49461)
2025 John Deere...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
