deepNdirt
Veteran Member
Hello all,
I think I have read someone else having this sort of issue as well, although not sure how far back in threads I'd have to go to find the answer?
So I hope Y'all don't mind me asking it again............ today while plowing my garden the tractor and all hydraulics working Great, when I finished plowing I pass by a Pompass grass plant on the way to park my tractor, I thought how fed up I get by having to cut grass around this thing, so I dug it up with the FEL took it to the back of our lot lift it over the 4 ft fence and dumped it on the other side to dispose of the evidenced,
the wife will be asking me what happen to it?
anyway on to park the tractor let the FEL down and then the rear but the rear 3 pt hitch would not drop, actually it was way up higher than usual almost hitting the back of my seat, I went ahead and shut off the tractor thought perhaps it would go ahead and drop? Nope! I re-started it and work the FEL and all work just fine with the loader hydraulics and again the rear wouldn't do anything, however I did notice that while working the FEL it was helping to release pressure to the rear but by very little, it started down slowly about 2 inches in 5 minutes, but once I started back with operating the FEL the rear would climb back up on its own,
all the while the rear 3 pt lift lever is all the way down, I of course fooled with this lever but had no effect what so ever on the lift, I also turned in and out on the knob under the seat and no change, looks like I'm stuck with the set of Harrows up in the air on my tractor untill I can be advised as to what the problem is :confused3: ????Please???? :anyone: and Oh! BTW its My YM 1700
