Rear Hydraulics
   / Rear Hydraulics #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
I am really interested in one of these dump trailers (http://www.countrymfg.com/cgi-bin/shop.cgi/page=2_ton_wagon.htm/SID=1111714864.17532) but I do not have rear hydraulics on my 1433V. Is there a kit available where this can be added? Have any of you done this addition? Is it something that a dealer needs to install or can I do it myself? Any photos of what it would look like? Any help from fellow Massey users is greatly appreciated!
   / Rear Hydraulics #2
I am looking to put a log splitter on my GC2300 and just called my dealer to put a hydraulic setup on the rear (Got too many things going on right now to attempt it myself). He said $250 to put in plumbing and connectors.
   / Rear Hydraulics #3
There are two different factory ways to add remotes to your 1433. One way and the one that you see most often is to add one or two valve bodies on the right side of the transmission case. The handles come up through the slots on the right of the seat. The other way and also the way that I have them on my 1440 is to get the valves for a joystick. The valves mount in the same place on the transmission as the first option does, but the joystick mounts to the right of the differential lock pedal. Either style works well, it just depends on your preference. To me the joystick version is faster and more convenient. I got the my joystick set-up from the factory by ordering the tractor as loader ready. By doing it that way, all I had to do was to reroute the lines and add mounts for the connectors. I then ordered a different joystick for the loader that mounts on the loader.
   / Rear Hydraulics
Jerry - I already have the joystick mounted on the fender and a tractor mounted valve; this is how the dealer set up my loader. Is there a way for me to tap off of that and run some lines to the back? Is there a way to keep the lines going to my loader and run the rear hydraulics or am I going to have to use a slector valve to choose between one or the other? I'm not concerned about lines; my nephew's work truck has a hydraulic line making machine on-board all I have to pay for is the crimp connectors at his company's dicounted price.
   / Rear Hydraulics #5
How do you feel about a having a joystick on the loader for the loader?
   / Rear Hydraulics
Well, I kind of like the joystick where it is for the loader... are you telling me it can't be done (having both the loader and rear hydraulics operational)?
What about the buttons on the joystick that currently do nothing? Couldn't they be set up to control rear hydraulics?
   / Rear Hydraulics #7
You could do it with electrically switched valves and even use the same joystick that you have to operate everything. The way I was referring to is the factory way. I do wish that MF would get their act together on additional remotes. If I didn't want the hydraulics set-up the way I have mine, I would bolt an arm to the roll bar with the control valve extended to above the right fender handle. Then just break in to the pressure line that goes to the loader.
   / Rear Hydraulics
</font><font color="blue" class="small">( If I didn't want the hydraulics set-up the way I have mine, I would bolt an arm to the roll bar with the control valve extended to above the right fender handle. Then just break in to the pressure line that goes to the loader. )</font>
Would I need to add a selector valve in line as well? To either direct flow to the loader or to the valve controling the rear?
Sorry if the questions are dumb or have been covered before; I'm new here and not up to speed on all the workings of the hydraulic system. Thanks for your help and patience...
   / Rear Hydraulics #9
Just a suggestion if you decide to go with a joy stick control for your rear remotes... I use remotes primarily for top&tilt cylinders, and had my control mounted on the crossbrace behind the seat where it joins the right fender. I figured any adjustments I made back there I would be turned to look back anyway and it's also where I can make adjustments to the lift arms from the ground to assist in hooking up implements, etc. If it's mounted over the diff lock, etc. you can't reach it from behind your tractor when hooking up.
   / Rear Hydraulics #10
If you add another control valve, you won't need a selector valve. The open center hydraulic system is designed to have the fluid flow through all the valves then back to the tank.
You could add electric valves and still use your loaders control valve. If you went that way, you could have a push button or a switch to select the circuit.
Fire Truck (A51692)
Fire Truck (A51692)
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
Case 586G (A50120)
Case 586G (A50120)
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Unused 2025 CFG H15R Mini Excavator (A50322)
Unused 2025 CFG...
