Rear Hydraulics on B7800 Kubota
   / Rear Hydraulics on B7800 Kubota #1
Barneyhunts
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
Does anyone know if there is a kit to install rear hydraulics on a B7800 Kubota?
THANKS!
   / Rear Hydraulics on B7800 Kubota #2
Yes there is a kit from Kubota to add 1 remote. It is expensive when compared to aftermarket (it is Kubota after all) My dealer said that it is a fairly easy install and comes with instructions and presized hoses. I am not sure where the valve mounts. I saw a picture on this site of a Kubota remote with an orange control box mounted on the lower front of the right rear fender. My dealer thought it used a conventional box mounted near the rear of the fender.
I had 2 aftermarket remotes installed on my B7800 by another tractor dealer. I did not have any hydraulics experience or time to figure it out when I needed the remotes. Now that I see them it is pretty clear. I could send you pictures and part numbers if you like.
   / Rear Hydraulics on B7800 Kubota #3
Kubota does have a kit that lists at around $650. but I'm not sure where it derives it's feed. There's only one outlet on the transmission. If you have a loader installed it takes that outlet so the kit must include some way of routing out of the single outlet block. Maybe a different block, I don't know..
Thank You folks for this information.
Jack
Howse 10' 3pt Rotary Mower (A50774)
Howse 10' 3pt...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
