Rear Hydraulics not working
   / Rear Hydraulics not working #1
JHK Farms
Maud, OK
Several, newest Bransons 4820
I received a 2000 NH 3415 with 218 hours from my brother's trust after a 2.5 year court battle by his 3 day bride. I got it running just fine, the rear hydraulics seem to work fine. Then the hydraulic pump starting grawling/whining. I checked the hydraulic fluid and found it had water in it. So I drained the Hydraulic fluids, which also include clumbs of hydraulic fluid/trash at the end. Rinsed the reservoir with diesel fluid several times and drained, then replaced the hydraulic filter that I purchased at the New Holland dealer and added the correct Hydraulic fluid. The rear hydraulics still do not work. What am I doing wrong? Do I need to bleed air out some where? The hydraulic pump is running smoothly. The tractor does not have a FEL. Thanks, JHK Farms
   / Rear Hydraulics not working #2
Do you have a steep hill? I think I'd be tempted to park with the nose down a steep hill to see if that helped. You probably have an airlock and the pump cannot self-prime. With water in the hydraulic system, your HPL valve might be stuck, but that's just a remote possibility. I looked at the NH diagrams and do not see a screen inside the reservoir for your tractor. Sometimes gummy residue can clog a screen in the suction pipe going to the reservoir, but I don't see one on your tractor.
Thanks Jim I will Check that. Waht I found is the hydraulic reservoir takes around 8.5 gallons empty? Let you know waht happens. But I think it is getting hydraulic fuid to the rar because there's a little box on the return line that you can unbolt. On top it has a decal with what looks like a finger punching a button on a calculator. When I remove that Bolt/plug looking bolt, hydraulic fluid comes pouring out. Hoby
   / Rear Hydraulics not working #4
Hoby, I think that "little box" is in the pressure line instead of the return line. The box sounds like the system diverter/pressure relief valve. The little book is telling you to refer to the Repair Manual for servicing/shimming the relief valve. If your hydaulic lines are two sizes, the large one is suction and the small one is pressure. The diverter block does have a return line attached because fluid from your relief valve goes through that line to the reservoir, but its main function is to regulate system pressure and to divert flow to a loader if installed.
Jim, I parked it on a steep hill over night, must have been an air lock. When I started her up, the rear hydraulics came up. No noise from the pump or any place. Now to clean her up and put her up for sale. I just don't need a third tractor at this point. Thanks for all your help.
Hoby
   / Rear Hydraulics not working #6
Chalk one up for the shade tree mechanic solution.:thumbsup::laughing:
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2019 INTERNATIONAL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
