Rear hydraulics for TC24DA? (messed up old post)
   / Rear hydraulics for TC24DA? (messed up old post) #1
gregp
Does NH offer a rear hydraulic set up for there TC24 tractors? I am going to run a Harley power rake with the hyd. angle feature and will need the equipment to do so. Kubota has a rear hydraulic setup for there b7610 tractor that they will put on at the shop. The Kubota is just not as purty as NH /forums/images/graemlins/grin.gif
SORRY! I SOMEHOW DELETED MY OTHER POST. I WAS TRYING TO CHANGE THE TITLE! I GUESS YOU CANT DO THAT! /forums/images/graemlins/confused.gif
   / Rear hydraulics for TC24DA? (messed up old post) #2
Greg,
I locked your other thread & directed people here to answer.
NH sells a rear remote kit for the TC24DA. It will give you 1 rear remote (pair of hoses). Cost about $250.
   / Rear hydraulics for TC24DA? (messed up old post) #3
There is a single remote (#718348076) available for the TC24DA. Dealer list is $255. It includes a hydraulic port block and cover that mounts behind the right wheel, and the appropriate levers/linkage to fill a slot on your tractor.
   / Rear hydraulics for TC24DA? (messed up old post) #4
In addition to what DocHeb and Hazmat wrote, if you order it, order it when you order your tractor. I got a quote from my dealership to install one on my TC24 and they were in the $500 range with the quote, had I gotten it when I got the tractor, it would have been 1/2 the price.
Thanks for the replys and part numbers. Can i assume this is what i need to run the angle cylinder on the power rake. The cylinders angles the rake 15 degrees left and right. The tractor on the dealer floor does not have the hyd. valve installed. We need to talk. /forums/images/graemlins/grin.gif
   / Rear hydraulics for TC24DA? (messed up old post) #6
The rear remote will allow you to control a single double acting cylinder, which is what I suspect controls the Harley Rake angle.
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
1/8" X 41" W X 81"L DIAMOND PLATE STEEL SHEETS (A51247)
1/8" X 41" W X...
(APPROX 20) 2" X 6" X 78" TUBING (A51247)
(APPROX 20) 2" X...
