Rear hydraulics for TC24DA? (messed up old post)
   / Rear hydraulics for TC24DA? (messed up old post) #1
gregp
Bronze Member
Does NH offer a rear hydraulic set up for there TC24 tractors? I am going to run a Harley power rake with the hyd. angle feature and will need the equipment to do so. Kubota has a rear hydraulic setup for there b7610 tractor that they will put on at the shop. The Kubota is just not as purty as NH /forums/images/graemlins/grin.gif
SORRY! I SOMEHOW DELETED MY OTHER POST. I WAS TRYING TO CHANGE THE TITLE! I GUESS YOU CANT DO THAT! /forums/images/graemlins/confused.gif
   / Rear hydraulics for TC24DA? (messed up old post) #2
Greg,
I locked your other thread & directed people here to answer.
NH sells a rear remote kit for the TC24DA. It will give you 1 rear remote (pair of hoses). Cost about $250.
   / Rear hydraulics for TC24DA? (messed up old post) #3
There is a single remote (#718348076) available for the TC24DA. Dealer list is $255. It includes a hydraulic port block and cover that mounts behind the right wheel, and the appropriate levers/linkage to fill a slot on your tractor.
   / Rear hydraulics for TC24DA? (messed up old post) #4
In addition to what DocHeb and Hazmat wrote, if you order it, order it when you order your tractor. I got a quote from my dealership to install one on my TC24 and they were in the $500 range with the quote, had I gotten it when I got the tractor, it would have been 1/2 the price.
Thanks for the replys and part numbers. Can i assume this is what i need to run the angle cylinder on the power rake. The cylinders angles the rake 15 degrees left and right. The tractor on the dealer floor does not have the hyd. valve installed. We need to talk. /forums/images/graemlins/grin.gif
   / Rear hydraulics for TC24DA? (messed up old post) #6
The rear remote will allow you to control a single double acting cylinder, which is what I suspect controls the Harley Rake angle.
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
