Rear hydraulics CK25/30HST
   / Rear hydraulics CK25/30HST
Would any of this be of any help with a rear finish mower??
It looks cool but would need some justification of cost.
I plan on maintaining a looong gravel drive with either a box blade or one of those drag behind driveway maintainer framework deals.
   / Rear hydraulics CK25/30HST #12
Top and tilt is really no help with a finish mower.
The are great/excellant help with a box blade, rear blade, rake, Etc.
I also use my top link a lot when I was clearing heavy brush areas. I could tilt up the back of my cutter, back into the brush and lower the cutter down using the hydraulic top link.
This way I could clear the worst brush areas on my property with the least amount of scratchs on my tractor paint.
My hydraulic top link gets used a lot.. Real handy feature to have.
   / Rear hydraulics CK25/30HST #13
The unit CCM sells (Integration Engineering) functions with only one set of remotes...
From the IE website:
<font color="blue"> Traditionally, the tractor needed one remote valve (2 hose outlets) for each remote cylinder (two cylinders). By using a joystick valve, Terrain Contour Control controls both cylinders through 1 valve requiring only 1 hydraulic connection to the tractor hydraulics. </font>
Don
   / Rear hydraulics CK25/30HST #14
The joystick setup would be nice. I've gotten very used to it with the fel. Maybe I missed it somewhere but what is the web site for CCM?
If you already have the two remotes for when attaching a backhoe, does lines run from them to the joystick and then to the hydralic links or do you tap into the hydralic system another way?
Thanks, Vic
so would you still use the factory Kioti rear hydraulic kit for the CCM?
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A58017)
2005 INTERNATIONAL...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Hose Reel (A55787)
Hose Reel (A55787)
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
