rear grease seal sizing
   / rear grease seal sizing #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I know I should have kept one of my old seals when I had the shop take them out, unfortunately I was in a hurry and forgot to take one. I took the hub to Auto Zone and their eye glazed over when I couldn't give them the number off the old seal. The spindle is 1 3/8" and the holes in the hub is just over 2.5". What size seal do I ask for?
   / rear grease seal sizing #3
Use a set of vernier calipers to measure the spindle were the seal rides, this will give you the I.D. For the seal , them measure to inside of the hub were the seal sets, this will give you the O.D. Of the seal. Then take those numbers to a reputable parts store, not auto zone. Another way is to remove a hub still on the trailer, clean off the seal face and get the number from it.
   / rear grease seal sizing #4
Go to a trailer supply, if you have any kind of standard axle they will have the seal.
Pretty standard by axle weight rating.
   / rear grease seal sizing #5
There should be a number on your seals. Since you dont have them you will have to use a caliper to measure.
Tractor supply dosnt have everything, the internet does.
So after doing the horse trailer earlier this month I finally got around to working on the flatbed. Once again the rear seals would not come out even with the seal puller. This time I ended up cutting and beating on them until they relented. I measured the spindle and the hub opening and sure enough they were the same as the ones on the horse trailer. This time I went to the Parts Plus guy and he at least knew enough to get a book out to look them up. In the end he didn't have any which didn't surprise me but I was hoping. So off I went to the RV store. I walk in and told him I need rear grease seals for a 3500lb axle. He doesn't ask anything else and just says you have two choices. He goes in back and comes back out with two boxes. One box contained the seals I needed and the other box had seals that were significantly bigger. I knew this shouldn't have been that hard. They ended up being only $1 more than I could get them from Amazon.
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
